Connection beetwen mesh portal with mesh point is intermitten
Hi all,
i have connection between 2 building with ap outdoor as connector, and it's always intermitten every 30mnts for around 15mnts. any idea what should i do for the configuration ?
Re: Connection beetwen mesh portal with mesh point is intermitten
Might be some DFS issues (weather radar or similer) - try using other 5GHZ channels , or disable 80mhz and use 40mhz only.
and <> please read bellow comment:
With IAP there is no functionality that prohibits an AP from changing channels when mesh is enabled (not really for AOS either). So if there's no clients on the 5Ghz radio (assuming you have client aware enabled) if the AP scans for 5Ghz and finds a 'better' 5Ghz channel, it will move, even with mesh enabled, and it's obviously very disruptive. In many cases the 5GHz mesh for instant is used when they just need to reach the last leg for client access Aps, but for bridged network backhaul, when you want the 5GHz radio to chose stability over the best channel, a static assignment should be used. It would be good to have some kind of logic where 'is mesh is enabled on the 5Ghz radio, only change channel if absolutely necessary'.
thanks for the response sir, i already disable 80mhz and i have tried change the channel to another one every time, but the connection still intermitten in around 30mnts for 15mnts
any another idea sir for configuration ?
is mesh portal can't send big packet through ?
Please obtain the tech support from the AP to see if there any clues as to why this is happening.  We need more information.
which log you want know ? such as "show ap database" ? may i know every command to show log for troubleshoot this issue ?
"show tech-support" would be the best command to capture everything.
already sent it sir :) , please review the log
How far apart are those access points?  It says that the RSSI is 50.  Also type "show log wireless all" and "show log system all" to see if there are any clues why these access points are disconnecting.  Also, "show ap tech-support ap-name <name of ap>" for each AP, to see if there are any more clues.
show ap mesh topology long
Mesh Cluster Name: aruba-mesh
Name              Mesh Role  Parent            Path Cost  Node Cost  Link Cost        Hop Count  RSSI  Rate Tx/Rx  Last Update  Uplink Age     #Children  Children
AP277-MeshPoint   Point      AP277-MESHPORTAL  1          0          0        1          50    54/54       4m:45s       5m:4s          0
AP277-MESHPORTAL  Portal     -                 0          1          0        0          0     -           5m:5s        2d:8h:57m:45s  1          "AP277-MeshP        oint"
length between APs is 110m and there is no obstacle between them,
i attach the log for "show log wireless all" , "show log system all" , and tech supp for each APs
