Frequent Contributor II
Console Cable for CP-HW-500
For ClearPass 500 , what is Console Cable type  ( nrmal or null ) &  what are needed settings Console settings ?
Re: Console Cable for CP-HW-500
Using the null modem cable provided, connect a serial port on the appliance to a terminal, then connect power and
switch on. The appliance immediately becomes available for configuration.
Use the following parameters for the serial port connection:
l Bit Rate: 9600
l Data Bits: 8
l Parity: None
l Stop Bits: 1
l Flow Control: None
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
If you found my post helpful, please give kudos
