Occasional Contributor I
Controller Authenticating to CPPM
I wish to check on the feature introduced in(from) the 6.4.2.5 release, where it allows to configure cppm username and password, in the radius server config.
conf t
aaa authentication-server radius <rad server>
cppm username <username> password <password>
what is this credentials actually? does the controller authenticate itself as dot1x client with the clearpass using that credentials?
Re: Controller Authenticating to CPPM
No, it's used with the downloadable role feature.
Tim Cappalli | Aruba Security
Thank you for reply, downloadable role featre?? Can i ask for a kb
document, on how its used?
Yogi.
