Frequent Contributor II
Controller, CPPM & Airwave fine tuning
Please share your inputs to fine tune/best practice/hardening of Controller, CPPM & Airwave.
Nik..
Re: Controller, CPPM
Thanks Cappalli..
Can some one share the CPPM & Airwave hardening the document.
Thanks....
There is a hardening guide currently in the works for CPPM. I believe there is already one on the support site for Airwave
Thank You,
Troy
The CPPM guide was just posted today.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=7961
Thank You,
Troy
does anyone know if a similar hardening guide for Airwave is available?
regards - Danny
