MVP
Controller claims certificate CN for its own?
So I've got a wildcard certificate formed as follows:
CN: host.domain.tld
SAN1: host.domain.tld
SAN2: *.domain.tld
host.domain.tld is NOT the controller, this is another actual server. The controller should respond to captiveportal-login.domain.tld.
I was trying to use (the wildcard portion of) this certificate on the controller for captive-portal auhentication.
Now, this works. Guests get this valid certificate presented so no more cert errors.
What is problematich however is that wireless users on the secure (non-guest) ssid, trying to access the server at https://host.domain.tld get redirected to https://host.domain.tld:4343 by the controller. The ip address also changes from the actual host to the controllers guest interface.
I understand that the controller graps traffic for that CN for itself for guest users, but why is it intercepting dns requests for users on other SSID's?!
Is this expected behaviour or what am I missing here?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: Controller claims certificate CN for its own?
What user role are those devices in?
Tim Cappalli | Aruba Security
MVP
As simple and open as I can get it:
(Aruba) #show rights user
Valid = 'Yes'
CleanedUp = 'No'
Derived Role = 'user'
Up BW:No Limit Down BW:No Limit
L2TP Pool = default-l2tp-pool
PPTP Pool = default-pptp-pool
Number of users referencing it = 24
Periodic reauthentication: Disabled
DPI Classification: Enabled
Youtube education: Disabled
Web Content Classification: Enabled
ACL Number = 78/0
Max Sessions = 65535
Check CP Profile for Accounting = TRUE
Application Exception List
Name Type
Application BW-Contract List
Name Type BW Contract Id Direction
access-list List
Position Name Type Location
1 global-sacl session
2 apprf-user-sacl session
3 allowall session
global-sacl
Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6 Contract
apprf-user-sacl
allowall
1 any any any permit Low 4
2 any any any-v6 permit Low 6
Expired Policies (due to time constraints) = 0
MVP
As simple as I can get it: allowall.
(Aruba) #show rights complete
Valid = 'Yes'
CleanedUp = 'No'
Derived Role = 'complete'
 Number of users referencing it = 28
 ACL Number = 75/0
Name  Type
access-list List
2         apprf-complete-sacl  session
3         allowall             session
global-sacl
apprf-complete-sacl
allowall
What's the output of "show datapath fqdn"?
MVP
host.domain.tld
That's why. You shouldn't​ use shared certificates from the rest of your environment with the controller. Use a dedicated certificate with an appropriate common name for your controllers.
MVP
ok, that's the current behaviour.. understood.
But can you explain why the controller would intercept DNS requests on an SSID where no role is configured to do so? Is there a good reason to do this?
It might be easier to except this truth if I understand the why of it :)
Because the controller will take the CN and add it as the redirect address in the controller when you import it.
