Controlleur Captive Portal Using Active Directory DataBase
Dear All,
can we   integrate Active directory with Controller Captive portal to authenticate AD users directly (without CPPM)
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Controlleur Captive Portal Using Active Directory DataBase
You have two options:
1.  Setup an AD server as an LDAP server and authenticate users directly to that via captive portal by putting the LDAP server  on the controller into the server group in the Captive Portal authentication profile.
2.  Setup an AD server as a radius (NPS or IAS) server and authenticating users by putting the radius server  on the controller into the server group in the Captive Portal authentication profile.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i've done a test before and it haven't work for me do you have any step by step document or some thing else please.
Regards
Raouf CHAHBOUNE
Please start here:  http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Internal_Captive_Portal.htm
