What type of cert are you using ?
What AOS do you have installed ?
Please enable logging level debugging user-debug <device mac>
Also run a show auth-tracebuf | include <device mac> and see what's happening during the authentication process
Check to see if the radius server logs if the EAP response is making it there
Do you see the DHCP discover coming from the device ?
You should probably open a TAC case
