Cppm and paloalto intragation
Hi expert
   I have a question.
I use 2 cppm servers. I configure insight master to cppm2 , cppm 1 enable insight. but cppm 1 is publisher.
Why cppm2 sent xmp-api to paloalto but not sent from cppm1.
Thank you all
Moderator
Re: Cppm and paloalto intragation
Updates to PANW are posted from the node that processes the authentication, irrespective of Insight or PUB/SUB..... ASSUMING your context-server config is correct.
Best Regards
-d
ClearPass Product Manager
Hi
thank you for your answer.
I enable insight 2 both server (PUB/SUB) .
ฺBut access tracker log autehntication and accounting have 1 cppm(PUB)
Thank you so much
Moderator
Sorry to ask, is there a followup question here?
Best Regards
-d
thank you for respone, I wait the answer for expert for solve and inform issue.
