Creating limited users for Mobility Controller
Is it possible to create a user in the Mobility Controller that has the same read only access as the built in basic role, but with the ability to reboot ONLY Access Points, not the controller?
Re: Creating limited users for Mobility Controller
That is NOT possible.  Do a search for "Default Management User Roles" in the ArubaOS 6.1 user guide to see exactly what each management user role can do.
