Contributor I
Custom Skin Help - Clearpass Guest Self Registration
Would anyone be willing to give me some help on how I can center the main form of the guest self registration page? I have centered my logo and text but having trouble centering the form itself. Thank you.
Re: Custom Skin Help - Clearpass Guest Self Registration
The <center> HTML tag works.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Contributor I
Can you elaborate a little? I have centered the title, header and footer and know how to use the center html tag, but I cannot find where to actually use the tag to center the form itself that is in the body. Thanks.
Try adding the center tag at the top of the header on the registration page.
Cheers
James
Which skin are you using?
Tim Cappalli | Aruba Security TME
Contributor I
Attempting to use custom skin 1. Adding the center tag in the header does not center the actual form with the fields the guest fills out. I have the headers, titles, footers and logo centered, just need to center the form itself. Thanks.
It centres the form on my CPPM lab when adding the <center> tag at the top of the header as mentioned. I'm also using the custom 1 skin.
Not sure why it's not doing it for you.
Where does the form reside on your page? Alligned to the left?
Have you added any customisation to the custom skin CSS?
Cheers
James
Contributor I
Take a look. Feel free to screen shot your setup in your lab so I can see what you are talking about. Thanks.
Add <center> in the Header HTML section at the top.
FYI You may also need to close the <center> tag you've got in the title.
Cheers
James
Contributor I
Thank you, that did it.
