Super Contributor I
Custom web-page without login credentials
All,
One thing that I'm currently looking to implement is a page that users would be redirected to that would tell them that they are quarantined and they should contact IT support. I've been playing around with the various web login pages, but each time - go figure - the login button is found in the middle of the page. Is there a way to remove this button in order to have a text only page?
Guest is not my stong suite, so any help would definitely be appreciated. Thanks!
-Mike
Re: Custom web-page without login credentials
Yes just checkmark use custom login
Thank You,
Troy
Super Contributor I
Troy,
I'm taking you out for a beer the next time I'm out in Sunnyvale. Spot on - thanks!
-Mike
Super Contributor I
Troy,
One additional wrinkle with this. I set it up as mentioned and then placed the CP profile into a user-role on my controller with a Captive Portal profile. It redirected to that webpage, just as expected. The one hiccup was that I could never leave this page.
I was hoping to do something like this:
1. OnGuard realizes a user's posture has changed to something not equalling HEALTHY
2. User will be redirected to the Quarantine Role
3. The user will see a captive portal page that informs them that they are quarantined
4. The user can go onto the Internet and download the required patches to fix their situation.
Right now I have the first 3 working as expected. I added the session ACL logon control and the captive portal to the role. I then removed each of them, one at a time, and tested again. No luck.
I would only like the user to be brought to the captive portal as a notification page, not as a walled garden. Any thoughts on this?
Thanks for your continued help!
-Mike
Mike,
There are a few things you can do and if you get a chance on Wed give me a call and we can see what works best for you. Then we can post the results here for everyone else. I do have a couple examples up in my lab. Take a look and let me know if any of them works for you.
1. One option is to give the user a role that has a firewall role where they are limited to just the update sites. With a forced destination that explains they are in violation and can not get full access until the device is updated.
2. If you are using the onguard agent it can update most dat files for you automatically.
There are a few others but I want to understand exactly what you would like to see and happen.
Thank You,
Troy
As most of you know, if you look at the supported AV, OS, etc. You will see that it looks like its ran by the energizer bunny. It just keeps going and going.....
Ok so this isn't a complete list and it isn't a small list, but it can give someone a start for a whitelist of the most common AV, AntiSpyware, and OS If you wanted to make a firewall policy. Feel free to add to the list.....:)
I also attached a txt file with the list. I started an arubapedia page and will post a link when its done.
akadns.com
akadns.net
akadns.org
akam.net
akamai.com
akamai.net
akamaiedge.net
akamaitech.net
akamaitechnologies.com
antivirus.com
antivirus.net.my
apple.com
atdmt.com
avast.com
avg.com
avg.cz
avgfree.com
avgtechnologies.112.2o7.net
avira-update.com
avira.com
bitdefender.com
bullguard.com
ca.com
clamav.net
clamxav.com
clamxav.net
cnet.com
com.com
d4p.net
digitalriver.com
download.com
drweb-online.com
drweb.com
dw.com
edgekey.net
edgesuite-staging.net
edgesuite.net
element5.com
eset.com
f-prot.com
f-secure.com
footprint.net
free-av.com
free-av.de
g.msn.com
gdata.de
globalsign.net
grisoft.com
grisoft.cz
gtld-servers.net
howtotell.com
html.it
inecnet.cz
invision.com
kaspersky.com
kolla.de
kundenserver.de
lavasoft.com
lavasoft.de
lavasoftusa.com
liveupdate.com
liveupdate.symantec.r3h.net
llnwd.net
mcafee.com
mcafeesecurity.com
microsoft.com
microsoft.net
microworld.com
msecnd.net
msft.com
msft.net
msftncsi.com
mwti.net
nai.com
netupdate2.intego.com
networkassociates.com
norman.com
norton.com
nsatc.com
nsatc.net
nsatc.org
onecare.live.com
pandasecurity.com
pandasoftware.com
pctools.com
rising-global.com
safer-networking.org
securitywonks.net
sfmirror.softlayer.com
sophos.com
sourceforge.mirror.iweb.ca
sourceforge.net
spybotupdates.com
spynet.com
symantec.com
symantecliveupdate.com
symantecstore.com
time.windows.com
trendmicro.com
trendsecure.com
unmetered.org.uk
update.nai.com.att-idns.net
webroot.com
windows.net
windowsupdate.com
windowsupdate.net
wustat.net
wustat.windows.com
zonealarm.com
Thank You,
Troy
Super Contributor I
Troy,
Sorry, I got wrapped up in a lot of work over the past few days. Yeah, send me a private message with some times that you'll be free in the upcoming week - definitely appreciate that!
I'm trying to do the equivalent of a one-time URL redirect. When a user currently is put into the quarantine role, Clearpass sends a message to their OnGuard client stating that they're in the quarantine role. I would love to also have their first web redirect be to a page that informs them of the same information. From there, they can go off and do their thing - but at least they were reminded of it once.
That's what I'm currently aiming for on the deployment that I'm working on.
Thanks!
-Mike
