Customer changed Certificate on their controller
We have a customer that changed their controller cert from securelogin.arubanetworks.com to one signed by their domain.   Now they are using Clearpass Guest so it is warning about the unknown cert on re-directs.  Do I just need to create a new self-signed cert to remedy this or is their another process to restore the securelogin.arubanetworks.com cert?
Re: Customer changed Certificate on their controller
Change the "Login IP address" field in your registration form to the common name of the certificate.
Tim Cappalli | Aruba Security
I did that and it prompts them since their domain cert isnt a public one.  Is there an easy way to revert back to the securelogin.arubanetworks.com public one so that the warning goes away?
Change the captive portal certificate back to default on the controller and revert that field back to securelogin.arubanetworks.com
Tim
