Contributor I
DNS problem with Apple devices
I am using 7210 controller with AP93H, the controller act as a DHCP server
I noticed that (some) of Apple devices don't optain the DNS automatically, while it optains the IP, Subnet and Gateway without any problem.
All Android, windows and other devices optain the DNS automatically.
I tested the same apple devices with other vendors and it optained the DNS automatically without any problems.
So it seems that is something related to Aruba, any one can help me ?
Re: DNS problem with Apple devices
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Which apple devices specifically?
Contributor I
IPhone, IPad and Mac Pro (Different Versions)
You should do a packet capture of a client with the issue to see if the controller is only sending it partial DHCP information.
http://community.arubanetworks.com/t5/Community-Matters-Blog/ArubaOS-6-3-New-Packet-Capture-Functionality-in-ArubaOS-6-3/ba-p/113967
