Contributor I
Data mining from Clearpass Guest
Hi all,
I have a client who is looking to use the captive portal within Clearpass Guest to collect information about guest visiting their premises (name, email, phone, company, etc) - is this possible directly from Clearpass Guest please?
Jamie.
Re: Data mining from Clearpass Guest
Yes, you can export data right from the Guest UI or leverage the REST API.
Tim Cappalli | Aruba Security
