last person joined: 11 hours ago
Data port and managemnet port Clearpass
  • 1.  Data port and managemnet port Clearpass
    Posted Nov 17, 2016 07:38 AM
    Hello
    When you got a Clearpass in which we will use both ports.
    If i got firewalls what ports do i need to open to it like this?
    From clearpass  management ip to internet
    http://clearpass.arubanetworks.com  port 80 and 443 to this website
    From clearpass managment ip to the email relay
    Mail - generally TCP 25 or 465.
    From the controllers in general to  the data port ip
    ClearPass Policy Manager/Guest Port Service
    3799 For RFC 3576 to work.
    1812 RADIUS1813
    RADIUS Accounting Server
    80 HTTP
    443 HTTPS
    From the guest user vlan to clearpass
    port 80
    port 443
    I am correct? im missing something?
    Both ports(managment and data port  are behind firewalls.  So i need to be clear this part.
    Also we are just using clearpass guest.
    Cheers
    Carlos
  • 2.  RE: Data port and managemnet port Clearpass
    Posted Nov 17, 2016 08:15 AM
    Hi Carlos,
    That looks like a good start. There are quite a few more port mentioned on the following post relating to NTP, database sync between CPPMs etc..
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/What-are-the-ports-that-need-to-be-opened-on-the-network/ta-p/175872
    Cheers
    James
  • 3.  RE: Data port and managemnet port Clearpass
    Posted Nov 17, 2016 08:20 AM
    I mised the NTP port thanks
    That NTP would be a port i need to open to the administration port of the clerapass right?
    We do not have a cluster of clearpass so i dont think i would need database sync between cppms
    So in my post the ports are correct? i mean all those ports i mention i should open them but for the data port?
    Cheers
    Carlos
  • 4.  RE: Data port and managemnet port Clearpass
    Posted Nov 17, 2016 08:41 AM
    Looks good.
    You'd also need DNS. :)
