Dedicated Clearpass Insight
Hi all
What is the consideration for dedicated clearpass insight node?
the technite said we need to consider dedicated insight node for large deployment?
what is the consideration of large deployment? is it the number of subs node? number of endpoint? or both?
i have a plan to deploy dedicated 25K publisher with 9 subs 5k node , with total endpoint around 30K (the client site spans accross large geoghrapical site), do i need dedicated insight node?
