Occasional Contributor I
Default country in phone selector
At registration.php I have an input field where you can select your country. Currently it is set to US, but since 90% of my guests are Danish, I would like to change it to be at Danish as default.
How is this possible?
Br,
Thomas
Re: Default country in phone selector
You can set that in the visitor_phone field. If you enter the self-registration flow, enter the form for the registration page, there edit the visitor_phone, you can set preferred countries that show up on the top of the list, and first is the default:Screen Shot 2018-05-09 at 9.56.49 AM.png
After that, the input will look like:
Thank so much :)
