Frequent Contributor II
Deleting cached users for testing
Hi:
I'm running Aruba controllers with CPPM and dot1x authentication.
After authenticating with a test user, I'm trying to delete that user from any caches, so that I can perform additional authentication tests.
I know that I need to delete on the controller with "aaa user delete x.x.x.x"
But I believe that I also need to delete the user on Clearpass? Can someone tell me where to do that?
Tony
Re: Deleting cached users for testing
Delete the device from the endpoint database in ClearPass (Configuration > Identity > Endpoints).
Tim Cappalli | Aruba Security
In the endpoint database there's an option that allows to clear cache
Thank you
Victor Fabian
Lead Mobility Architect @WEI
