MVP
Dell Switches with CPPM
Hi Everyone, I have a question.
I'm testing Dot1X wired policy with clearpass and I don't see the Dell in the "Vendor Name" field when adding the network switch , any recomendations on what vendor to choose? I would like to test some RADIUS actions, like VLAN assigment base on authentication results(if not authenticated assign Guest VLAN),  Radius CoA, etc, thanks a lot in advanced.dell.JPG
Oscar,
“All opinions written here are my own and do not necessarily reflect the views and opinions of Aruba.”
“If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos"
Re: Dell Switches with CPPM
Which variant of Dell switches?
Tim Cappalli | Aruba Security
MVP
DELL Nxxx series, I'm testing with a N2048p  version 6.3.xx
Oscar,
AFAIK, they do not use any vendor specific attributes. You can likely just
use IETF as the vendor.
MVP
Thanks, I will go ahead and choose IETF.
Oscar,
