Valued Contributor I
Detailed logging of endpoint classification process
Running CPPM 6.7.2 and 6.7.3
Can someone tell me where to enable debug logging of the endpoint classification process  when you are relaying DHCP requests to a clearpass server defined as the primary server in a zone.
Also, if you define a primarty and secondary server in a zone, if a dhcp request hits the secondary server will it get processed even if the primary server is active or is it an active/passive thing ?
We *think* that endpoint classification isn't working for our production cluster. We can see it working on a dev cluster without the need for detailedf logs but a bit stuck on the prodn one
A
