Frequent Contributor I
Different SMTP Sender for Guest
In ClearPass Guest, is there a way to configure the Email receipt sender field to be different than the CPPM admin sender field setup in the SMTP messaging setup? For example, CPPM admin sender is cppm@yourcompany.com. Can I set the sender field for my guest receipt to be something different, like guest@yourcompany.com?
Thanks!
Re: Different SMTP Sender for Guest
I don't believe this is possible today.
Tim Cappalli | Aruba Security
How about today?
