Contributor II
Different radius group by AP group
I am running ArubaOS 6.1.3.6 on M3 modules (6000 series controller) in different geographic locations setup in a master/local configuration.  All locations use the same VAPs, but different AP Groups.  We currently use the same radius server group for the VAPs across all geo locations.  However, we want to add a radius server at one location and have the APs in that AP group use that local radius as the primary radius server and a radius server in the original location as the backup radius server.  Is there a way to do this with the same VAPs in different locations?
Aruba
Re: Different radius group by AP group
You'll need to create different VAPs with different AAA profiles to reflect the different radius servers.
AMFX | ACCX | ACDX | ACMX
Contributor II
I believe I know the answer to this but can the different VAPs have the same SSID name?
Hello.
You can have more VAPs with same ESSID profile and more AAA profiles.
Eg.
VAP1=ESSID+AAA1
VAP2=ESSID+AAA2
ESSID profile can be same.
Jaroslav
Contributor II
Great!  I will give it a try.
Aruba
Yes you can do that; in fact most of my installs have one SSID Profile for each network; then x number of AAA and VAPs; depending on their authentication requirements.
You cannot have two of the same SSIDs in the same AP Group however.
Contributor II
Thanks all!  I added another VAP with the same ESSID but with a different AAA group and it worked.
