Regular Contributor I
Display vcname
I would like to display the name of the VC on my guest self-registration login page. So I use $vcname, it works but only the first time I access the page. If I navigate to an other page and go back, the name is no more displayed.
Any idea how to keep it ? Perhaps to pass it in an other variable that stays active ?
Dimitri
MVP
Re: Display vcname
Hi Dimitri
You posted about this before, right?
I think a solution would be to pass this in the url you have on your landing page. How does the url look like? Or - is this after you've submitted a form?
Another way would be to have multiple landingpages with different names so you just have different urls that your vc redirect to..
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Re: Display vcname
Yes, allready posted, I have moved a bit forward but I stil have the problem that the variable $vcname is only diplayed the first landing on the page.
I don't want to have multiple landing pages, too hard to maintain.
I think the best way will be to keep the vcname in a variable perhpas in the cookie or session but I haven't found how to do it.
Regards
Dimitri
MVP
Re: Display vcname
Wll Dimitri.
How do a user navigate from one page to the next? Is that through URL's or form submits?
The parameter vcname comes in the redirect URL from the InstantAP - so you can use that directly like:
{$vname}. If you want to use the SSID - I believe you can use {$site_ssid}.
Now - first how to solve the URL click to navigate part.
In the footer I placed this code to create a link that also takes with it the parameters in the URL:
<p><a href="urltest.php?{$smarty.server.QUERY_STRING}">Next page</a>
</p>
Now - if you navigate by submitting a form I would assume you can add a field that is populated by the value in the $vcname variable.
You could also check if the variable is saved in any other variable. Add this code to the footer of the subpage to see what parameters are there:
{dump var=$params export=html}
Regards
John Solberg
Re: Display vcname
Thanks, it's working fine with adding ?{$smarty.server.QUERY_STRING} to my urls.
Perfect solution :)
Thanks again.
Dimitri
