Not sure if you were able to create the vlan-name under the master controller :
(master-controller) (config) #vlan-name ?
<name> Vlan name <1..32>
(master-controller) (config) #vlan-name test
And once you define the VLAN number under the local controller:
(local-controller) (config) #vlan test ?
<vlan-ids> List of VLAN IDs(0-removes all vlans)
We were able to setup something similar using ClearPass
Hope this helps.
