Does AOS consider DHCP Inform from client when Enforce dhcp is turned on
Hi Team,
I would like to know if user will come up in user-table when it sends DHCP inform rather than sending discover with 'enforce dhcp' enabled in AAA.
Client sends dhcp inform when it wakes up from sleep mode.
Karthikeyan
