Does Clearpass work with VMware NXS?
Re: Does Clearpass work with VMware NXS?
Please elaborate.
Tim Cappalli | Aruba Security
Contributor I
Do you mean with VMware NSX? I think no direct linkages between Clearpass with NSX since NSX is virtualized networking mechanism on VMware environment. If you are looking for whether Clearpass can installed on VMware vSphere, the answer is yes.
