Frequent Contributor II
Does onboard have agent called quick connect?
Hi guys,
I want to understand is the quick connect the onboarding application like on guard for health checks?
and how to deploy it?
Re: Does onboard have agent called quick connect?
QuickConnect is used by Onboard to install certs on Windows and Android. It does not install. It's a utility.
There's also a standalone QC option which does standalone 802.1X configuration.
Tim
Tim Cappalli | Aruba Security
So Dear Tim,
you say that the quick connect application I can install it on any widnwos for example and it will configure this machine for 802.1x thats what I knew,now about the certficates how it will be known for the qouick connect and it is company property ?
If you want the standalone utility that just configured the client, it's a separate product that you would have to purchase.
If you're using it as part of Onboard, all configuration is done based on the provisioning profile.
QuickConnect does not have any role in determining device ownership. All of that would still be done using policy manager authorization.
Tim
so Qouick connect for 802.1x should be paid for?
If you need supplicant configuration and not certificate/credential enrollment, then you would use the standalone QuickConnect product which is a cloud portal that generates a package for use on Windows, Mac, Linux, iOS and Android.
Tim
so do you know what is the part number for the quick connect standalone app?
QC-1-C 1-year subscription, 1-1000 users (per user)
QC-2-C 1-year subscription, 1001-5000 users (per user)
QC-3-C 1-year subscription, 5001-10000 users (per user)
QC-4-C 1-year subscription increments of 10,000 users (per user)
Tim
