Frequent Contributor II
Dual SSID onboarding
Hi all,
I dont know if is there any document on this or not.
I want to create dual SSID onboarding. Means at first user will connect through a open SSID and after  that when the user will try to browse he should redirect to onboard page. After running the quickconnect app user should move to a different SSID by completing EAP-TLS authentication.
Thakns
Rana
rana
Re: Dual SSID onboarding
Is your open network also going to be serving guests? It's a waste of airtime if you're solely using it onboard enrollment unless you have a specific technical requirement.
Tim
Tim Cappalli | Aruba Security
No i dont have any technical requirement.
I am learning Clearpass and all the things. So thats why i want to know is there anything so i can accomplish this.
Rana
rana
This should get you started on setting up the basic guest portal and .1x. Then you will need to add in the onboarding to the guest page.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=10345
Thank You,
Troy
Regular Contributor II
