Contributor I
EAP-TLS Authorization Required
I've been looking through the forums and from what I can understand, the "Authorization Required" option in the "Edit Authentication Method" box is to compare the Username in the certificate agianst AD. Is this correct?  Does this add additional security? What is a good use case for this?
Also, I've tried to enable it and when I do, I get an error in the logs saying that the user can't be found. When I uncheck/disable it, it authenticates just fine. Trying to fiure out what might be the issue.
Re: EAP-TLS Authorization Required
EAP-TLS essentially has it’s own authorization as part of the Authentication phase, then it moves onto traditional authorization. If you’re receiving an error, it’s likely that you need to compare a different field or username format.
Please post screenshots of the alert and summary tabs from access tracker.
Tim Cappalli | Aruba Security
Contributor I
Thanks Tim for the info.
Please see the errors/logs attached.
Is your AD auth source configured for both sAMAccountName and userPrincipalName?
Contributor I
It looks to be just sAMAccountName. But I don't know much about setting up attributes. I've attached what I beleive you are asking for. If I need to add userPrincipalName, is this done in the "Filter Query" under the Filter Name...which we have labeled "Authentication"? And is it either or? Or both? ...like both sAMAccountName and userPrincipalName? Thanks!
First confirm in AD that the username presented is indeed the user's UPN.
If you want to support both username formats, replace your Authentication filter query with:
(|(&(sAMAccountName=%{Authentication:Username})(objectClass=user))(&(userPrincipalName=%{Authentication:Username})(objectClass=user)))
Ideally, you should choose one username format from a user experience standpoint. Fully qualified username (UPN) is always my recommendation these days.
If you have enabled Username strip in the 802.1x service, please disable and try EAP TLS authentication with authorization enabled. Also, please make sure that you have added the correct AD authentication source in the 802.1x service.
Contributor I
This worked! Thanks for the help!
