Contributor I
EAP TLS with ADCS for machine auth
I've searched and searched and can't quite find a thread on here with the same symptoms. What I'd like to acheive is doing machine authentication with our Macs using a certificate assigned from our AD CA. I've got what I think is a very basic service configured, but the client keeps failing with "user not found". According to Access Tracker, it's not looking at AD as the authentication source even though it's specified.
-Mac laptop (10.13.4) joined to AD
-It's getting the AD, ClearPass, and trusted CA certs via profile manager (I'm 99.9% sure this is all working as it should)
-AD CA cert installed in ClearPass trust list
-EAP TLS with authorization checkbox unchecked
-AD authentication source with default settings, working fine for EAP PEAP on production SSID
What am I missing?
Screen Shot 2018-04-26 at 9.53.47 AM.pngScreen Shot 2018-04-26 at 9.53.59 AM.pngService config - 2012 AD as auth sourceScreen Shot 2018-04-26 at 9.54.10 AM.pngAuth source "none"Screen Shot 2018-04-26 at 9.54.21 AM.pngUser not found
Re: EAP TLS with ADCS for machine auth
Remove the authentication source from your service.
Tim Cappalli | Aruba Security
Contributor I
Ok that works, but I had to change my role mapping rules. I had tried that, but my role mappings were based on AD attributes so it was still failing, just with a slightly different error message.
Just to be clear, this service is only handling machine authentications, correct?
Contributor I
Yes it is, but this is only a test service. The plan would be to eventually add it to our production service which is now only doing EAP PEAP for user auth. I'm pretty sure I saw a config in an old thread for how to do that.
It would be better to keep machine auth in its own service since authorization is not enabled.
Contributor I
Makes sense. Is there a way I can do that if it's using the same SSID?
Yes, services are not tied to SSIDs.
Use service rules that check for:
Authentication:Full-Username BEGINS_WITH host/
Authentication:Full-Username ENDS_WITH .yourdomain.xyz
