Contributor II
Enabling Endpoint Classification
Hi
Quick question about enabling endpoint classification
I have a CPPM cluster - two nodes.  Currently I have profiling enabled on both nodes. One handles Wifi and the other LAN and will cover each other on failure.  Should it be enabled on both nodes?
Is there any issues if I leave it on both?
Re: Enabling Endpoint Classification
Do you have a VIP configured between the nodes?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Hello there
Yes - I have a VIP, I use it for the captive portal at the moment.
M
Then just use the VIP for the profiling
Thank you
Victor Fabian
Contributor II
my VIP is xx.xx.80.1
and that points to the publisher at 70.9
so the advice would be to untick endpoint classification on the subscriber 70.8
