Encryption when authenticating ldap in clearpass
Hi! Our current setup is we have 2 controllers and a clearpass. How can we encrypt our authentication if active directory is integrated in clearpass using ldap over ssl? thanks for your inputs!
Re: Encryption when authenticating ldap in clearpass
If you're using LDAPS, the traffic is encrypted between ClearPass and the LDAP server.
Tim Cappalli | Aruba Security
Hi Tim,
Do our client need to have public ssl certificate in order to do ldaps?
No, but you need to ensure the LDAP certificate is added to the ClearPass trust list.
Thanks Tim!
If you prefer watching a video, check out this video.
