End point profiling doesn't work on Clear pass
Hi All,
We are  configuring Aruba clearpass for Mac bypass authentication for ip phones, but this doesnt work because the end point respository shows the phones as not profiled. In the network switch we have configured ip helper address as aruba clear pass and required radius parameters are provided for MAB authentication.
To my understanding  DHCP should act as a collector and automatically profile the ip phones , let me know if any parameters need to be specified.
should we have dhcp snooping or snmp configured for profiling to work correctly?
I have read through docs but unable to get a proper answer.
Request inputs.
Re: End point profiling doesn't work on Clear pass
You need set the IP address of your clearpass server as one of ip helper address on that SVI.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
We have configured clearpass ip address as the ip helper address, but the end point respository shows not profiled.
Do we need to configure anything specific on clearpass  as well for getting the devices profiled.
We are using 6.0 version.
Do you see anything in the endpoint profiler ?:
Thank you
Victor Fabian
Also make sure you have it enabled
Thank you
Victor Fabian
Super Contributor I
Also ensure udp 67 (both src and dst ports) are allowed to clearpass.
Ryan Holland, ACDX #1 ACMX #1
The Ohio State University
