We Authorize our Remote APs via an Aruba Activate Endpoint Context Server configuration in ClearPass. We just got some of the new AP-203R's. Unfortunately they are not noted properly in Activate for the default Aruba Activate Endpoint Context Server. If there an recommnded change to the Device Filter to allow the 203R's?
Thanx - Eric
So that filter is on the "Part" field? I thought it was on the "Part Description" field. ... Or is it both? Is there refernece material for this stuff?
