Contributor I
Endpoint Cleanup Question
We are investgating the implementation of more rigid clean up intervals in order to reduce our endpoint db.   We are currently running CPPM 6.5.  In our test environment I have worked with all of the available interval settings and believe I understand them all.  That said I am left with a number of unknown endpoints that are not profiled having no attribute.  I dont see a setting where we can remove unknown, non profiled endpoints. We have tested in our testbed; max inactive time for an endpoint, known endpoints cleanup interval, unknown endpoints cleanup interval , profiled unknown endpoints clean up interval,and even played around with the profiled endpoints option set to true. All these settings will produce the desired results but we are still left with "stale" unknown, non profiled endpoints.  Please advise.  Thanks.
