Trusted Contributor I
Enforce Machine Authentication
I have a test environment setup, using ClearPass 6.X and an Aruba controller.  I've setup a policy that needs to verify both the user and computer are in the domain.  The computer and user authenticate just fine, but there seems to be a problem with my  enforcement policy.  I have 2 conditions:
Tips: Role EQUALS [user authenticated] > User Role
Tips: Role EQUALS [Machine Authenticated] > Machine role.
The user role profile enforces a user role and the machine role profile enforces a machine role.  The machine authenticates properly and receives the machine role.  Then, the user authenticates and receives the user role.  My expectation was that since the machine authenticated and then the user authenticated that the controller would assign the default dot1x role.  I have this working properly with a Windows NPS server.  However, this isn't happening with ClearPass.  Any thoughts?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Regular Contributor I
Re: Enforce Machine Authentication
So is User Role defined as a RADIUS Enforcement profile in CPPM? If you select it does it show Action: Accept  ?
You can also try to add an attribute as follows:
Type: Radius:Aruba
Value: <NameOfArubaRoll>
ACDX, ACCP, CISSP, CWNA
Yes, my enforcement profiles contain the user role and machine role.
In production with my Win NPS server, the following happens:
1. Machine authenticates > machine role assigned
2. User authenticates > authenticated role assigned (default dot1x role)
In my test CPPM lab, the following happens:
2. User authenticates > user role assigned
Aruba
So, I assume you have 'enforce machine authentication' setup on the dot1x authentication profile, correct?
Regardless, a server derived rule (from CPPM in this case) is going to override the defualt dot1x role; so the response from CPPM is going to overwrite the default dot1x role if machine/user authentication pass.   If you want to use the user/machine/default roles of the dot1x profile, then do not apply any Aruba-User-Roles in the CPPM enforcment profile/policies; just allow them to pass.
AMFX | ACCX | ACDX | ACMX
Yes, enforce machine authentication is checked.
If I remove the enforcement policy that I created from the service and select the [sample allow access profile], the user is getting fully authenticate without having to machine authenticate first.  To test this, I disabled wifi and deleted the MAC from the user table.  Then, I re-enabled wifi.  I checked the controller and had the authenticated role, when I should've had the user role.
Aruba
try your test again, but in addition to your steps run the following to make sure you remove the user fully form the user table:
aaa user delete <ip.of.client>
Same result.
Aruba
Run the follow to see how the user got that role.
show user ip <ip of user>
Look for the line that says:
Role Derivation:
Role Derivation: default for authentication type 802.1x
Uncheck enforce machine authentication and allow CPPM to assign the roles.  Enforce Machine authentication changes the rules...
