Error 404 on Clearpass Web Administration
Mi client has a Clearpass Policy Manager on production environment for about 3 months so far, all working right.
Today in the morning my client tried to connect to the web server and the following error shows:
Estado HTTP 404 - /tips/welcome.action
type Informe de estado
mensaje /tips/welcome.action
descripción El recurso requerido no está disponible.
Apache Tomcat
We have verified that the clients can still authenticate as always.
I have tried using the command: service restart cpass-admin-server (Log attached) but the web server won't work.
We are going to try a reboot of the Clearpass VM on the afternoon after 6 pm when all the wireless users leave, but I wanted to know if some has any extra command or information to check before proceeding, or if someone got a similar problem.
Best Regards
Luis Regis
Re: Error 404 on Clearpass Web Administration
Could it be that you locked down application level access the the ClearPass Admin UI?
That is configured: Administration » Server Manager » Server Configuration > <your clearpass node> .> Network > Application Access control.
If your deployment is locked down (which is good) and administrators come in from an unauthorized IP address (maybe the network was renumbered), it could be that you see this 404 error.
If you still have access to the console (appadmin), you can reset the application access control from there:
[appadmin@cppm1-pub]# system apps-access-reset
Policy Manager application access is restored
Stopping httpd:                                            [  OK  ]
Starting httpd:                                            [  OK  ]
After that, you should have access again.
