I am running into some trouble that I think may be caused by some double quotes being added to an if statement within the Guest Self Registration portal. The issue I believe is that the addition of these double quotes is breaking some java script futher down the page.
The If statment is the standard statusCodes check for Cisco contollers:
{if $statusCode == 1}
{nwa_icontext type=info}
**INSERT ERROR MESSAGE HERE**
{/nwa_icontext}
{/if}
Which is interpreted on the html page as:
<div class="nwaError">
**INSERT ERROR MESSAGE HERE **
</div>
How do I remove those double quotes?
