Example of 802.1x wired connection with OnGuard on Aruba switch
I implemented 802.1x wired service on a 3800 switch with radius authentication and attempted to add OnGuard to check firewall usage. I managed to get the port to shut down when firewall is disabled but I can't get it to work after firewall is enabled. Is there an example of such an implementation that I could refer to?
Haim
