Expired Clearpass Licenses - Do I need to match quantities when renewing?
I have a Clearpass server that has 500 Enterprise licenses on it currently, and they are about to expire.  Looking at the license usage over time, 500 is more than I every use on this particular server inclusive of policy manager, guest and onboard.
My question is, can I lower that number when I am renewing the licenses (to 300 total which will cover the needs of this particular CPPM) or do I need to renew all 500 because that is ariginally what it was confiugred with?
Re: Expired Clearpass Licenses - Do I need to match quantities when renewing?
The minimum ClearPass Policy Manager Base available license is 500
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Aha, I knew there had to be a reason.  Does that hold true for Enterprise licenses as well?  I know that I can order fewer than 500 Enterprise at a time.  As I said, I'm using them for a combination of Onboard and Guest as well as default client access so I do need them. If 500 is the minimum total, then 500 it is, however if 500 base and 300 Enterprise is supported that would cover my needs.
The ClearPass Modules or Enterprise can be order this way :
Enterprise :
LIC-CP-EN-100 | LIC-CP-EN-500 | LIC-CP-EN-1K | LIC-CP-EN-2500 | LIC-CP-EN-5K | LIC-CP-EN-10K | LIC-CP-EN-25K | LIC-CP-EN-50K | LIC-CP-EN-100K
Thank you
Victor Fabian
