Valued Contributor I
Exporting radius authentication/accounting info via syslog
It's been suggested that I can use a syslog export filter to send clearpass radius authentication and accounting info out to a remote syslog server... which in turn could push it into logstash.
The problem with just proxying the accounting via a service is that you don't get the auth info, just the accounting
Have made an inital stab at doing this but can't see any traffic on the remote server so obviously I'm doing something wrong. Anone out there doing this sort of thing?
Rgds
Alex
Re: Exporting radius authentication/accounting info via syslog
Sigh!
Helps if you tell rsyslog to listen on apropriate UDP port for inbound traffic!
many thanks
A
What syslog facility/level is used to send logs to the server ?
I believe it’s level1
Tim Cappalli | Aruba Security
local1
o.k. got radius logs being dumped into a single file called radius.log now
thx
A
