External Captive Portal
Ok so I had a test IAP 215 from Aruba for testing before purchase. I setup Radius and my own captive portal for guest access. Everything was working great so before giving back the demo I backed up the config.
Purchased new IAP 315 restored the config from the test device and that loaded the config great. But now I cannot login through the captive portal and it seems to have to do with this line in the index file  <form method=POST action="http://securelogin.arubanetworks.com/cgi-bin/login"> with this it will just spin and spin till i get a webpage not available. FYI once someone logs in it takes them to my companies .edu page. If I change it to this  <form method=POST action="https://securelogin.arubanetworks.com/cgi-bin/login"> it will ask to add the certificate and I can login fine. But I didn't need that https in the previous config.
Any help with this would be great thanks
Alex
Re: External Captive Portal
Did you upload your captive portal certificate?
Tim Cappalli | Aruba Security
I did not upload a captive portal cert. I did not know I had to as it worked fine previously with the test device.
thanks
How do I upload this cert? Is this becase when restoring from the previous device it is using that Cert?
thanks
The cert previously included was not designed to be used in production environments. Please take a look here:
https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
