Occasional Contributor I
Extreme switch Vlan enforcement
Hi all
I'm trying to set up Mac authentication with extreme switches. They don't support radius COA messages so we can't move a device in to a different Vlan after posture checking when it sits behind a phone.
Has anyone had experience of SNMP or http based enforcement profiles with extreme switches or other ideas on how to handle it?
Re: Extreme switch Vlan enforcement
Could you solve this issue with Extreme Switches? I have the same issue and need support.
Any help will be appreciated.
