F5 BIGIP and Clearpass CPPM (AAA)
I'm looking to use Clearpass CPPM for AAA and F5 BIGIP.
I am in the process of configuring an enforcement profile and in the "Services" tab where "Selected Services", I'm not sure what to choose
Anyone have experience in successfully configuring F5 AAA to Clearpass?
Re: F5 BIGIP and Clearpass CPPM (AAA)
There is a technote here that is specifically tailored to F5 and CPPM
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
If you found my post helpful, please give kudos
Ok, after scanning the document (I admit I haven't read the whole thing yet) I did not see any specific information on how to configure CPPM to do AAA for the F5 admin login.  Did I miss something?
Correct.  The document is only about load balancing the CPPM traffic.
Colin Joseph
Aruba Customer Engineering
Nope - I never planned on adding that. Its all about LB'ing backend CPPM servers.
Best Regards
ClearPass Product Manager
Did you even get an answer to using CPPM for admin auth on F5 devices?
While I have done this in the past (and can provide some of the config setup of needed), I was looking to see if any has tried it with some of the new features in BigIP 12.x?
I believe one of my team has figured this out, but I haven't been able to get them to share it with me yet.
