Frequent Contributor II
Fail to joined domain on clearpass
Adding host to AD domain...
INFO - Fetched REALM 'CPPM.COM' from domain FQDN 'test.cppm.com'
INFO - Fetched the NETBIOS name 'CPPM'
INFO - Creating domain directories for 'CPPM'
INFO - Using Administrator as the TEST's username
Enter Administrator's password:
kerberos_kinit_password Administrator@CPPM.COM failed: Ticket is
ineligible for postdating
Failed to join domain: failed to connect to AD: Ticket is ineligible
for postdating
INFO - Restoring smb configuration
INFO - Restoring krb5 configuration file
INFO - Deleting domain directories for 'CPPM'
ERROR - CPPM failed to join the domain CPPM.COM with domain
controller as test.cppm.com
Join domain failed
Aruba
Re: Fail to joined domain on clearpass
The clocks on both servers are too far apart. Make sure the use the same NTP server
Thank You,
Troy
Regular Contributor II
Please make sure the account you are using to join CPPM to domainthat is Domain Admin user
