Contributor II
Failed Back-Ups using DataPuller
Afternoon
I've set up the datapuller config file to pull configs from a new cluster but  getting the following error in the datapuller client log:
2018-05-11 14:33:31,861 ERROR  DataPuller PyWGet ERROR: Failed to open the URL {https://172.17.125.73/tipsapi/config/fetch/ServerConfig}. Reason - HTTP Error 401: Unauthorized
Traceback (most recent call last):
  File "/usr/local/avenda/datapuller/lib/datapuller.zip/PyWGet.py", line 106, in wGetData
  File "/usr/lib64/python2.4/urllib2.py", line 130, in urlopen
    return _opener.open(url, data)
  File "/usr/lib64/python2.4/urllib2.py", line 364, in open
    response = meth(req, response)
  File "/usr/lib64/python2.4/urllib2.py", line 471, in http_response
    response = self.parent.error(
  File "/usr/lib64/python2.4/urllib2.py", line 402, in error
    return self._call_chain(*args)
  File "/usr/lib64/python2.4/urllib2.py", line 337, in _call_chain
    result = func(*args)
  File "/usr/lib64/python2.4/urllib2.py", line 480, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
2018-05-11 14:33:31,870 WARNING DataPuller DataPuller Caught exception while constructing DataPullerConfig for IP 172.17.125.73
  File "/usr/local/avenda/datapuller/lib/datapuller.zip/DataPuller.py", line 150, in __buildDataPullerConfig
  File "/usr/local/avenda/datapuller/lib/datapuller.zip/DataPuller.py", line 30, in __init__
  File "/usr/local/avenda/datapuller/lib/datapuller.zip/PyWGet.py", line 113, in wGetData
DataPullerException: ERROR: Failed to open the URL {https://172.17.125.73/tipsapi/config/fetch/ServerConfig}. Reason - HTTP Error 401: Unauthorized
We have two existing clusters backing up configs using datapuller successfully.
We are running version 6.6.8 on CP-HW-5K
Many Thanks
Re: Failed Back-Ups using DataPuller
The error message 401 Unauthorized suggests that you have an error in the admin username or password.
Having said that, DataPuller is an old and unmaintained utility since remote backup was added to ClearPass quite some versions ago.
Please use the ClearPass built-in backup tool, which can be configured from Administration » External Servers » File Backup Servers.
