Contributor I
Firewall ports for ClearPass and PaloAlto integration
 Can someone tell me please what ports do I need to enable on the firewall to integrate the ClearPass with the PaloAlto firewall?
Ivan Vera
Re: Firewall ports for ClearPass and PaloAlto integration
TCP 443
Tim Cappalli | Aruba Security
Contributor I
Thank you
