Fortigate with Guest Captive portal
I had a customer where I was trying Clearpass to authenticate Guest user against the fortigate firewall built in Wireless Controller.
I used the following URL to setup the fortigate and to authenticate the user
I was able to work with the Aruba TAC Rajesh and we were able to achieve full authentication by having the custom attribute under the NAS vendor setting of clearpass.
Please see screenshot... for reference.
Re: Fortigate with Guest Captive portal
hi sir / ma'am
can you share configuration on the clearpass? thanks
Hi Migs,
Is there anything specific you are looking for, I created the basic self resgistration portal with the policy manager servcie profile for RADIUS authentication.
