Regular Contributor II
Fortinet and Clearpass
Hi all,
Does anybody using fortinet wireless with clearpass for guest self regestration.
I need some suggestion ..
Valued Contributor II
Re: Fortinet and Clearpass
Hi Suman,
Please share your requirements so that, I can give you a better solution.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
I am looking for guest self registration in fortinet wireless with
Clearpass.
I just checked and saw that they are doing captive portal with internal
only. [*Captive portal page and user id both are coming from internal DB*]
There is no option to add external captive portal page, If its there
please let me know.
Does anybody integrate a fortigate with Clearpass as radius server?. In the radius test, pass success, But when i put the autentication as captive portal or 802.1x for wifi, The autentication fails.
With other Radius, server works fine.
Any idea?
