Frequent Contributor II
Frame-IP-address attribute on clearpass
Is Frame-IP-address attribute used for ?
I think, It's used for identify IP address on client right ?
Thank you
Re: Frame-IP-address attribute on clearpass
Yes, usually it is the IP address of the client.
Tim Cappalli | Aruba Security
